which amp to get?
music and rise dont really go together...
so to be clear, how much is the rise when playing music? Last competition i went to, they clamped my hifonics brz1200d and i got ~860wrms @2.8ohm after rise, playing 43hz tone.
tone is the key word, when playing music the ohm load is constantly changing. but you can account for rise only on tones or a nice solid long note in a song that is constant. The rise is more of your box than the amp.
so in order to limit rise, i need better box design?
I've got.a.audiopipe 3k for sale with modded speaker terminals...we could work something out.on a price and that would be a good match for those subs plus would give you headway if you wanted to add another sub or 2 down the road
i'm limited on electrical, 3k would be too much.
Just cause it can do 3k dosnt mean you have to use all that power...and there pretty easy on electrical.
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
400-2500ish
Hammerdown... 1%
Get rid of the kinectic and go with 2 of the biggest xs batterys that will fit replace stock one with xs do the big 3 and at least one run of 0g or more front to back.I'm assuming you have d1 subs id go with a 3k amp if u want at lest 2k because in a perfect world your rise is going to at least be 2ohms in a musical box and that would put you at the power your looking for with a 2k amp. My box rise is 5ohms but on certain freq I can protect my amp from low impedeance playing music
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I was thinking of just getting xsd3100 and keeping kinetik, subs are D4's wired down to 1 ohm. I'm not sure about big 3, because my battery is in the back.
Edited by LoudBimmer
So i'm guessing Sundown or DC will do ~2000wrms on music and ~1200-1300 on tone after rise?
No one knows, you would have to test it yourself. Music is dynamic so you won't see the same power at all times from it.
you got it backwards, it will do more power on tones than music
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
