which amp to get?
music and rise dont really go together...
so to be clear, how much is the rise when playing music? Last competition i went to, they clamped my hifonics brz1200d and i got ~860wrms @2.8ohm after rise, playing 43hz tone.
tone is the key word, when playing music the ohm load is constantly changing. but you can account for rise only on tones or a nice solid long note in a song that is constant. The rise is more of your box than the amp.
so in order to limit rise, i need better box design?
I've got.a.audiopipe 3k for sale with modded speaker terminals...we could work something out.on a price and that would be a good match for those subs plus would give you headway if you wanted to add another sub or 2 down the road
i'm limited on electrical, 3k would be too much.
Just cause it can do 3k dosnt mean you have to use all that power...and there pretty easy on electrical.
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
400-2500ish
Hammerdown... 1%
Get rid of the kinectic and go with 2 of the biggest xs batterys that will fit replace stock one with xs do the big 3 and at least one run of 0g or more front to back.I'm assuming you have d1 subs id go with a 3k amp if u want at lest 2k because in a perfect world your rise is going to at least be 2ohms in a musical box and that would put you at the power your looking for with a 2k amp. My box rise is 5ohms but on certain freq I can protect my amp from low impedeance playing music
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I was thinking of just getting xsd3100 and keeping kinetik, subs are D4's wired down to 1 ohm. I'm not sure about big 3, because my battery is in the back.
Edited by LoudBimmer
So i'm guessing Sundown or DC will do ~2000wrms on music and ~1200-1300 on tone after rise?
No one knows, you would have to test it yourself. Music is dynamic so you won't see the same power at all times from it.
you got it backwards, it will do more power on tones than music
Team_DC-Derrick's Youtube
Team DC Audio
  • Who's Online   1 Member, 0 Anonymous, 1336 Guests (See full list)
