I have two amps that have only one channel on each my question is does it really matter how i wire them?
friend told me to wire each sub to its own Amp but i want to know if it really matters...
Like if i wire both subs parallel to one amp versus wiring both subs in parallel individually to there own seperate amp?
my question is does it matter..
sorry if my question is confusing.... :mad:
amps ohm loads.
1 ohm: 1200 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
4 ohms: 500 watts x 1 chan.
14.4v
Edited by Mesto
they're both Pioneer Premier PRS-D1200SPL
Edited by Mesto
if you wired each sub to their own amp in parallel, you can kiss those subs goodbye! so rule that out.
wire both subs in parallel to ONE amp. thatll leave you with a 1 ohm load.
wait....you said you had 2 dual 4 ohm type r's?? why did you take it off???
took them off because they're only 500 rms and the amp at 1 ohm is 1200 even though i was told the type rs can handle like 800-1000 watts..
ok i have the type rs so if i wire them to 1 ohm boom they're gone but ok i have some used mtx subs coming to me soon description says 1000watts rms...now does it matter if i wire them to one amp or should i just wire each sub to there own amp...
EDIT: I will return tomorrow when i am not as tired i cant even form a sentence and im confusing my damn self at the moment LOL im going to bed...
Edited by Mesto
the biggest problem with one amp on one sub and another amp on another sub is the gains
its almost impossible to get them exactly the same
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
use a DMM and its not so hard to get em real close.
why dont you use just one amp, wire up the 2 type Rs to get 1 ohm and set your gain right
sell the 2nd amp or whatever
Edited by nauc
Alpine 9887, Oz 180CS, RF R500X1D, 12" RE SE
  • Who's Online   0 Members, 0 Anonymous, 1664 Guests (See full list)
