Help me interpret clamp test numbers
SPLadd1ct
These numbers are from my buddy Chris (kickassaudio here on SMD). He runs two Massive Audio DB8000.1's strapped to an SMD 18. The clamp results he achieved are below.
Wired to .5 ohms resting:
30Hz track, 2794.5 watts at 1.38 ohms after rise
35Hz track, 3431.85 watts at 2.03 ohms after rise
40Hz track, 4843.3 watts at 1.368 ohms after rise
45Hz track, 5127.15 watts at 1.16 ohms after rise
__________________________​________________
wired to 2 ohms resting:
30Hz track, 612.5 watts at 6.4 ohms after rise
35Hz track, 762.3 watts at 9.41 ohms after rise
40Hz track, 1470 watts at 6.53 ohms after rise
45Hz track, 2208.4 watts at 4.48 ohms after rise.
Take notice to the two lines I highlighted in bold above. Why is it that at 30 and 40 hertz the impedances are nearly identical, but a 40 hertz burp yields over 2000 watts rms more?
Can someone please explain this phenomenon to me?
Thanks
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
On the 30hz track the amps and volts were just lower than at 40hz. It just happens that when you divided volts by amps in both cases that it came out to similar reactive ohm loads but when you multiple the larger numbers together you obviously get more power.
As a request from my man Cody (CJ18) here are the clamp and dmm readings i obtained while burping the system
Loaded down at 2 ohms resting:
30Hz: 9.8 amps, 62.5v ac
35Hz: 9.0 amps, 84.7v ac
40Hz: 15 amps, 98.0v ac
45Hz: 22.2 amps, 99.5v ac
_____________________________________________
Loaded down at .5 ohms resting:
30Hz: 45 amps, 62.1v ac
35Hz: 41.1 amps, 83.5v ac
40Hz: 59.5 amps, 81.4v ac
45Hz: 66.5 amps, 77.1v ac.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
  • Who's Online   0 Members, 0 Anonymous, 1164 Guests (See full list)
