MustangGT Posted August 13, 2011 Report Posted August 13, 2011 A friend of mine has two 12in. L7's And two jl 500/1, Whats the best way to connect them.
ChevyBoy95 Posted August 13, 2011 Report Posted August 13, 2011 what coil config are the L7s? dual 2s or 4s? but regardless its going to be 1 sub on each amp. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
MustangGT Posted August 13, 2011 Author Report Posted August 13, 2011 Sorry i forgot to include That. They are d2.
bassaholicsfl Posted August 13, 2011 Report Posted August 13, 2011 Wire postives together and negatives together. Run wires from 1 postive to postive output 1 negative to negative output. Someone on here has a diagram heres a link for diagram http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3 2001 Dodge Ram Quad Cab.
Supercharged DCs Posted August 13, 2011 Report Posted August 13, 2011 Wire to 4ohm with each woofer, and you will have to gain match the amplifiers. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
MustangGT Posted August 13, 2011 Author Report Posted August 13, 2011 Thanks. Will it be more efficient wired at 4ohm compared to 1ohm. ?
ChevyBoy95 Posted August 13, 2011 Report Posted August 13, 2011 Wire postives together and negatives together. Run wires from 1 postive to postive output 1 negative to negative output. Someone on here has a diagram heres a link for diagram http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3 they are only stable down to 1.5 ohms. wire each sub in series to get 4 ohms, and wire 1 to each amp. series is positive from coil 1 to negative on coil 2, and positive on coil 2 to amp positive, and negative on coil 1 to amp negative. and do that with each one. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
