8" dual 2ohm L7's
is the equivalent volume[vas] not what i should be going off of?
I think that's the volume of air the cone moves. I could be (and likely am) wrong.
EDIT: Reading around a bit, it seems as if vas is the amount of air equal to the amount of force needed to move the spider? Is that a correct understanding?
My 12 inch level 4 only displaces .18 cubic feet.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
No, vas is not the amount of space the woofer takes up, it is the amount of air whose compliance is the same as a drivers. It is a T/S parameter, and you can read more about that here.
So kicker recommends for their "spl" box to do 1.0 net ft3 tuned to about 44-46hz for each sub.
If you want me to I can design a box and get you a sketchup of it for free!
Just give me your max dementions and weather you want a slot port or aero port and I'll come up with a few different variations of it!
I think I'm just going to end up doing fiberglass under my rear seat so it will be about 2.5 ft^3 befor port and subs so if you could let me know what a good port size would be that would help alot. The port max dimensions would be 10" wide, 4 " tall and 12" deep.
  • Who's Online   1 Member, 0 Anonymous, 1235 Guests (See full list)
