Ive got 2 RE SEx 12s and the box they are in just sounds lame imo dosnt hit low at all and dosnt sound very loud at all. The specs i got from the RE site that was recommended for the subs. The specs for the box are 3cub tunes to apparently 28.75hz
I just did another box but bigger tho im not sure if its going to make a difference... not sure if its even done right =/ i dont know how to work in inchs lol only know mm
My max dimensions in the back of my car are:
H 400mm - 15.747inch
W 990mm - 38.975inch
D 650mm - 25.589inch
If anyone knows a better box design id love the help!!!
Also pretty much every box i see on here has a 4inch port opening why have them so wide?
Edited by ExtremeOz
Needs more port.
That dont exactly help me lol... What you mean?
I mean you don't have enough port area. I'd shoot for around 55sqin of port.
You can change the in to mm in the options I'm pretty sure
If only it had that option =(
60sqin not 31sqin
I do that by widning the port width yes? if so i changed it to 4" but then the Hz went way up to 55+hz i changed the port length but i had to change it by some rediculas amout just to get it back to 37hz. Sorry im epic fail when it comes to ports =/
Edited by ExtremeOz
60sqin not 31sqin
you have to work the box size along with port length and width to get your desired port area and tuning.
EDIT: I WENT RETARDED AND DIDNT CHANGE PORT HEIGHT AND ACCOUNT FOR THAT SO MY PIC IS USELESS!!!! SO I TOOK IT DOWN TO PREVENT CONFUSION!
Edited by ChevyBoy95
  • Who's Online   1 Member, 0 Anonymous, 3049 Guests (See full list)
