warm subs and not enuff beat
did you wire up one sub at a time?
did you wire up one amp at a time?
did you unslave the amps and try them ran at two ohm each or one ohm to each amp
you have to isolate the possible issues.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Still sounds like a wiring problem. I have strapped aq amps before 2 1200s then I upgraded to 2200s. I would try hooking up all 4 subs to each amp individually forget the second amp for now. make sure they both work fine then if they are both working alright pull the subs out of the box triple check the wiring in there as well and make sure everything is hooked up right. I like the buss bar type hookup you have but you hook the coil of the sub to the leads to a terminal to a wire to a bar to another wire to the amp? Not saying you dont know what your doing but I like to try and keep it as direct as I can so its harder to make a mistake. In addition to having the - coils of the subs hooked to the + outputs on the slave amp and the + to the + on the master amp I believe you need to jumper the - outputs from the master amp to the slave amp.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
This. I had a problem way back with a clif design amp on a 4 15'' setup and its a major bitch but you have to try each sub out by itself try pairs of 2 on each amp at 1 ohm. Sucks having problems you just gotta be willing to take the time to figure it out. Theres a reason 2 subs are moving more than the other 2.
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
Ok so I THINK I may have figured it out!... I basically have 1 vc of each sub. Pos 2. Neg. When it suppose 2 b pos to neg of other vc! So basically I think I'm only using 1 vc per sub! (Ugh dumb ass) lol gonna rewire again after work and pretty sure that should fix prob. Opinions?
if it doesnt fix it.. just gain match them, forget the master/slave bullshit LOL, if its not loud then, then you have something to worry about
Team_DC-Derrick's Youtube
Team DC Audio
that should probably fix it. with only one of the two voice coils wired up you have a completely different final ohm load than what you thought you had. also not using the subs to their potential
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
Well still nothing... 2 work 2 dnt... called local stereo shop. They want 60 a hr book me for 3hrs to figure it. Said I pry fuckd a amp up .. thing is only 2 subs work other 2 almost sound blow.. so preety much burn out wth this all. So idk what 2 do... if I blew a amp or both or. 1 or more subs I'm gonna be devestated! I already pretty much am
what about bills on here. isnt he from there.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 767 Guests (See full list)
