OK I have a Bit of a issue, Im Having to many different ideas for system design.... I have a Budget for 1400 bucks Amps/Subs Everything else is Taken care of 2 D3100s D3400 and a mechman 270 alt in a 2005 jeep grand cherokee I have space for 3 12s maximum and cant really fit anything bigger than 12s, Im tryin to achieve mid 140s on the meter not really a huge deal if i dont get it but im going for lower tuning prob 33hertz. I just need some options or and idea is this really even Feasible or should i look into some other area of bass the main thing i want from this Build is AIR FLOW...
Options or Suggestion on Equipment are welcome :drinks:
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
what if you went with 6 10's? that would get you more cone area than 3 12's so it would probably move more air and could fit in around the same space.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Even though you got the sub amp taken care of it'd be nice to know how mcuh power you are working with.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
I Have enough system support to effectively run ied say prob 5k
not a bad idea but i dont know of 6 10s that i could balance out in my price range.
You'll be hard pressed to get some new equipment, especially if you plan on running 5k, on that budget. You should look in the classifieds and look out for something like some audiopipe amps, or maybe a used 5k of some sort. You can probably find one for between 7-800. That will leave you with a good 6-700 for subs alone. Is wire taken care of or is that included in your budget? Do you have proper deadening done already? What about funds just to purchase wood and assemble your box? Because 1400 just subs and an amp(s) is fine if you can deal with a used amp or used subs, but if you have to fit other install needs into the budget you will be even more hard pressed and might need to tack on another 2-300 onto that budget. I would still suggest scouring the classifieds for some used larger amps or a couple lower powered budget amps, a audiopipe 3k would do you just fine. Then hit up DC or Sundown for some prices on subs.
wood is taken care of just ordered another 50 of knu Fleks this am... I'm not necessarily looking to run 5k i have enough electrical do support it thought.. I know 1400 is not alot to work with thats why ive made arrangement to have everything else i need already taken care of i have 150 sq feet of second skin waiting to be installed
Then I would look into what the guy below me posted. The Crescendo amps are pretty stout, and his suggestion will be right around your budget, maybe a bit high if you go with 3 of the Audioque subs.
  • Who's Online   0 Members, 0 Anonymous, 1361 Guests (See full list)
