T line for,two twelves!!!
brent379
ok, i could be wrong but according to FIs site, the SD or effective cone area of a fi x 12 is 481 cm^2 which is roughly 74.56 in^2 so, shouldn't your port area be 74.5 times 2 which is 149, or you could go with 150 to for easier measuring
like i said i could be wrong, but i thought it went off the SD of the subwoofer
correct
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
edit: you posted before i noticed, LOL
yes wide x deep is the port area, then times that by the length gives you total volume, but its the wdith and depth you need to know for port area
12 x 16 is about 28% larger than your port area really needs to be
a 15 x 10 port area should make that easy to work with 15 being the dimension the baffle would be with and 10 being the depth
now would you want it firing UP or to the side, i ve seen it done both ways with good results, but never seen a tline in a truck, but ive seen firing up into the corner with good results on a normal ported design above window line
if firing up id say, sub up and port up, 2 bends and then the last one would change direction to fire in the same direction as the sub is facing, based on width of your truck should get you near your tuning
would be roughly 22.5 inches tall overall, 16.5 inches deep and however wide your truck is, you wouldnt have to use entire width, but as logn as you get desired tuning
you can also taper the line a bit if you need to, there are other ways to design the tline rather than just a constant port area, though constant port area is my favorite its also the largest of the designs of the tline i believe
You are really making this harder then it has to be. Kynto is right by using the SD. You can't measure from surround to surround and call it done as its a CONE, not a Flat CIRCLE.
Sound travels at 1130 feet per second. Divide that by desired frequency then divide by 4 to get the length you want. Most people use the fs of the sub to get the frequency they want.
simple, done. It you still can't figure it out stop asking us and go back to 5th grade math class.
constant line area is the most idiot proof
you are right sir, LOL
if i hadnt run out of graph paper i may do a quick sketch, i need to print more graph paper off (yes i make my own, store just doesnt have the size i want, LOL)
suppose could throw a sketch up together though
couple of other notes. you can "tune" above the fs of the sub but never below
you can have less port area than the sd but never more
play under "tuning" at your own risk tlines have no back pressure and will allow a sub to unload very quickly
make the airflow in the box as smooth as possible
and do not have any air leaks. it ruins the enclosure. majorly
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Sick! I finally think i got it!! Thx for all the help i really appreciate it! Ima start designing it asap. and thx for ur smart a$$ comment sanitarium.... Its not the math part that gets me its mainly getting the formulas right... Everyone has to start somewhere and nothin like havin a prick to talk down to ya!
As long as you realize that even being a smartass I was trying to help. Tough love and such. Glad you figured it out!
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
