T line for,two twelves!!!
brent379
Ok. I got two fi x twelves in an extended cab dakota and i wanna build a tline for them but im confused on how to get specs for the box...can someone,plz help me out!!!!
Have you read the sticky on them?
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
9 foot long port with a port area of roughly 2(π6²)
Good luck
His max width should be around 4ft, so it would have to bend 2 times, right? 4ft->bend->4ft->bend->1ft. Do you think it would be possible if, say, he walled off the vehicle? I'm just curious is all.
Whoa wait how did u get 9 ft?????? Ive read quite abit on them and im havin a hard time understanding it all....i mean i can do a 9 ft port in a box but how do u go about finding how tall...deep...and wide the box should be for the,tline?? I need like a simple break down fron the,beginning...i REALLY wanna do this bad!!!!
9 feet is the length of the box because the entire box is the port. However many times you have to bend it to get the internal length to be 9 feet is up to you.
8 feet is about 35hz tuning
9 feet gets you 31.4hz.
282.5/length = tuning frequency. 282.5 is 1130 (speed of sound) divided by 4 (quarter wave theory) btw. Read the sticky...
Hammerdown... 1%
best way to design a tline is with a piece of paper (graph paper works well) and a pencil
the way that work best for me is two bends. air flow goes right, then left, then forward.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Ooooo ok im starting to get it now.. If i read the sticky right... The port length should equal or be close to the total cone area of both twelves right????
No, the port area is determined by the total cone area. The port length is determined by desired tuning.
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
