Hi Guys,
I have build a few boxes but aint pro by any means and could really use some help at this point. Problem is I wanted to go with aero style ports but it is way too long for the desired tuning freq which is 18HZ. Will be used for HT/Music/Pissing off neighbors. My goal is more to get the best SQ out of them with good low end extension rather then to get loud.
Drivers 2x fully loaded Fi BL 12's
my calculations this far...
Port area based on Fi guideline's
42min
56max
5" x2 39.25
4" x4 50.24
3" x6 42.39
With this the 4's looked like the ticket but the port will have to be 3 meters long in a box that is only 3.5 CBF after displacement. I guess my question is how to go about this without tuning much higher. I could make the box bigger but 3.5cbf is right in the middle of the recommended range.
Thanks
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
Did you figure this out?
I'm not a "pro" either but i can try to help based on a little bit of experience. My suggestion would be to go bigger on the box, when you want a tuning way out of what's in their recomendations you might also have to change other things. But you have to be a little more careful with how much power you are pushing. With a low tuning I think you can get away with a little smaller than recomended port area. I think this has to do with the air moving slower and changing direction fewer times over a given time, resulting in less air velocity in the port.
Funny enough I actually have a subwoofer in my room tuned to 18hz. The driver is 12" and that one alone is given well over 3cbf.. But it also have a different spider/cone setup making it more effective at low frequencies than those BL's. I went with slot port and built it around the back of the box, and I think its over 1.5m long. But the port is way bigger than relly nesessairy. Don't remember port area though.. And many corners are kerfed for god airflow :)
And if you really want a good woofer that goes deep, I would also recomend to maybe looking at different drivers, But if this is to just utilise those subs, never mind.
I hope I didn't write all this for nothing :No:
i bet u could get away with a single 6" with a elbow
REP
Thanks man,
Yeah there is still hope and you didnt reply for no reason. I took the BL's out and will be replacing them with a BTL eventually and there is no point trying to sell a high power driver in these parts; so I though whatever ill use them for my HT.
Having less port area will actually be good in reducing the port length :) If it will work fine then it might just work. I will buy a crown amp to power them once the dealer pulls his finger out of his butt. The thing his I live in a apartment complex so doubt ill ever push them to rated power which correct me if im wrong will make the issue of port noise even less?
Build Log>>>
New Build
yeah thanks ill look into it.. Problem is I was told that more smaller ports were better for SQ applications. Whether it is true or not I wont know but I suppose there would be many variables and I suppose with the BL being a bit of a hard-hitter sub it should be a non issue.
Have you used those PVC rain gutter pipes for port tuning? I think I might be able to get some in Black and then maybe heat them up and flare them with a metal bowl?
Build Log>>>
New Build
