I have a pioneer deck that had 3 separate RCA plugins. There is a front, rear and sub one. I have 3 different sets of RCAs going the 3 different amps. I have four kicker 6x9s on one amp, 2 kicker 12s on another amp, and four kicker 6.5s on the other amp. i just installed the amp for the 6.5s today. The RCAs for the sub amp are of course hooked up in the sub plugin on the deck. i had the amp for the 6x9s hooked up the the front plugin on the deck ans it worked fine. Now today i go to hook the amp for the 6.5s up to the front plugin and the amp for the 6x9s to the rear plugin and a wierd buzzing sound comes out of the speakers. If i unplug the RCAs that are hooked up to the 6x9 amp the noise stop. Im not aware of this problem and not sure how to fix it. Any ideas?
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Might be the amp, check to see if you smell burnt by the amp. I had a similiar problem. Also make sure if theres metal parts on the rca's, and that they are not touching.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
ground loop it its not a pico fuse issue you have bad rcas or bad gorunds.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I was thinking it could be ground but if he has 3 amps, I'm sure they are running the same ground spot. If he's running the 3 and only one sounds bad it possibly couldn't be the ground could it.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 1652 Guests (See full list)
