not sure if i'm posting in the correct forum...i'm trying to wire 6 dual 4ohm 10's to a 1.33ohm load. wiring them in series/parallel...problem is i can't seem to get it right. i've followed 4 different diagrams and still can't get it right. i've got all the subs going, but it's reading 5.1ohm at the amp. what could my problem be? i've got my + to the amp coming off sub #1 and - coming from sub #4.
Youve got the wrong coils tied together. You need to have the postive from one coil to the negative on the other coil. Run the positives from 3 subs out and 3 negatives out. Do the same on the other three subs and when they meet the amp(if its a mono) they will have a 1.33 load. Each set of three will bring 2.67 ohms to the party.
i'm using the wiring diagram from jl audio. have you seen that diagram? should i wire three and three, then they all meet at the amp?
Jl audio has a diagram on this. That's how i initially wired mine. But Sierra is correct. Series each woofer than parallel all remaining coils
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I don't need to see the wiring diagram you're referring to. As simple as you can keep it in you head, is the best way to do it. That's why I suggest doing 3 and 3 so you can keep everything coherent while youre doing it. Try to go to the12volt.com or rockford fosgate's site and select 3 D4 for the option.
i appreciate the help. i'm going to try the rockford 3 d4 and see what happens.
And I thought I had issues wiring 4 subs.. Kudos to you man.
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
