Guys have to come some time developing my project SPL. now almost in the final I came across a doubt. what kind of decision to use?
I am very influenced by the projects of Steve Meade, something I shaman much attention are the boxes with threaded rods to avoid vibrations.
And here what else strikes me the screws instead of the traditional outlets
In my project using cables to each sub 6mm (4 pioneer 309), IRAM they unite in a terminal lug inside the pier just past out to screw as in the examples above, this screw (outside) to the module using vo 16mm cable, plus there is a doubt use a bolt as in the photos above I'm going to have loss of power?
imagem.JPGTaking into account that a bolt of pure copper and very difficult to find. I will lose power by placing a screw joint of steel?
What else interests me there is beauty that does not suffer from loss of power. WHAT do you think?
(excuse my mistakes, I'm braseleiro, not in English)
:trippy:
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
:trippy:
Oh it's not that bad. Just imagine what it would sound like if you translated English to his language trying to ask a question.
What he wants to know is how much power he will be losing by using steel bolts for speaker terminals on his box. I really don't know the answer though.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I hope you can translate this back to brazialian.
It doesn't seem like you would lose that much power using the steel bolt terminals. If it worries you that much, just use the holes you have drilled for the bolts and run your wires through them then silicone them up to seal it.
EDIT: You could also run the wires through your port if that is an option.
As far as using the all-thread for strengthening, I've always heard wood is better for bracing because it won't flex as much.
By the way, the word "Boner" has a completely different meaning in English lol.
Edited by Rev. Wrath
Yeah I opened this thread expecting it to be in the 18+ section.
x2 lmfao
but there will be some Resistance in the bolt but not enough to worry about it
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
You're not going to lose enough to make it noticeable, as long as you use stainless steel bolts at least 1/4" (8 to 10mm), and solder your terminals. The ease of using bolts gives you more flexibility in wiring your subs,especially if you have dual voice coil subwoofers.
If you want something more elegant, try these http://www.parts-express.com/pe/showdetl.cfm?Partnumber=091-1247 although I don't know if they ship to your country, maybe you can find something like this locally.
Stay away from terminal cups.
Good Luck!
:drinks:
2007 Pacifica
Good Luck!
:drinks:
OHHH now those are nice!
  • Who's Online   0 Members, 0 Anonymous, 1446 Guests (See full list)
