Posted (edited)
hey guys!
i was having issue and i was thinking it was my mechman alt not giving me any output, but when i finally had bought a new ddm hoping it wasnt my alt and my cheap ddm that wasnt telling me the correct output, so i got a new fluke 115 and my front battery was 14.2-14.3 which is fine since i was seeing 13's with no load, but i realized that wasnt an issue whats so ever it was my back d3100s in my trunk there not getting a charge what so ever with the car off it was 12.8 and with the car on it was also 12.8 why could that be??? im confused on that
Edited by KnockinthaStreetzof608
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Fuses? Replace them even if they look good.
Big 3 with Yellow Top
all fuses are fine, but i plan on running my batterys with 2/0 wire so ima go without any fuses in the near future
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Your asking for a fire by not using fuses
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
but to help you fix your problem. put the dmm on each side of the fuse and see if there is a difference. If so its your fuse
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
Dude, put fuses in. One little short in that 2/0 and poof....
what fuse rating will you give 2/0 wire then?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
well i just checked and my runs from the front d3400 to the back is fine it reads 14volts but for some reason once my postive hits the back d3100 its just drops to 13.4?!
WTF?!?!?! why would it do that
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
check your grounds for the back battery make sure where ever them batteries are grounded to are tight and clean so they have a good connection.
Time to rebuild.
TEAM DTF
