voltage no matching to battery bank(alternator not chargin?)
Um disconnect and check both batts seperately.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
well i just checked and my runs from the front d3400 to the back is fine it reads 14volts but for some reason once my postive hits the back d3100 its just drops to 13.4?!
WTF?!?!?! why would it do that
check your grounds for the back battery make sure where ever them batteries are grounded to are tight and clean so they have a good connection.
well for the grounds i dont have any in the back at all, i did was just run 1/0 wire from my d3400 thats under the hood and put it in the d3100 so i have two runs in total one for postive and one for negative
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
how big of a fuse do you have running to the back batteries now
300 amp fuses, but when i did my testing i took off my fuses
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
i did that already =(
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Aaaannnnnddd???/ What did they both read?
Big 3 with Yellow Top
when nate said to disconnect them did he mean remove my d3400 from under the hood? and put the d3100 and see what it reads?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Second. Voltages on each battery?? It wouldn't hurt to take them to AutoZone/Napa/etc... and get them load tested.
Also like has been said- do continuity tests on your fuses, grounds, and power wires.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Im pretty sure he meant disconnect them from all cables and read their resting voltage.
  • Who's Online   1 Member, 0 Anonymous, 1640 Guests (See full list)
