CJs F150- 8/10..1 9k??? Nope....2!!!!
i completely take back my statement about your score being low i didnt realize those were lvl3s i thought you had xls thats why i was like wtf
Yep they are 3s. the whole goal of this was to get a 153+ with cone area and low power and on a budget. If i would have gone with XLs and the proper power for them(3 7.5ks and about 20 D1400s), I would be into this about 20k. Instead I have done this entire build from front to back, everything from wire to subs, amps, and batteries for under $6000.
thats awesome props my hopes with my rebuild is a 55 im picking up my camper shell sunday so the box build is starting soon
I really feel that this build has a legal 155 in it. Just need to find that extra 1.57db hiding somewhere.
There might be some left in the box. Awesome numbers also. I gained a db or so using 1 1/2 abs roundovers on the port and edges of box dc ftw
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i bet you could see the 55 with the 7.5k
I am open to any simple suggestions that do not require any changes to the box. This was not intentionally built for the meter, it is built to sound good and make people not want to sit in it. It just happens to do fairly well on the meter. Now if I can get it 150+ from 30hz-50hz then I will be happy.
nice scores mang!!
i bet you might gain some just by trimming out the wall probably not much but every little helps in dont know what your coltage drop is but you said you plan to add more batts and another run of + so that will help and how do you have your subs wired parallel/parallel is proven to be louder than series/parallel
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
I am going to see what it does today with a fully charged battery bank. I have been sitting about 16.4 and dropping to around 15v. Hopefully I can get a little extra with a full charge. I have a feeling that I will be seeing a legal 154 today.
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
