MrSkippyJ Posted August 29, 2011 Report Share Posted August 29, 2011 witch=scary woman that rides a broom which is the version fo the word you are looking for I was just being funny, or trying anyway. oh well i have speech problems but when i split the remote wire from the radio connected to the harness do i split both ends of that wire and tie them in with my amp remote wire? Which is why I wasn't an ass about it yes you need all 3 wires to connect. That wire also turns your radio on. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
bigmescan Posted August 29, 2011 Report Share Posted August 29, 2011 Take remote and memory wire and hook them to the yellow/red switch wire then hook power wire to constant if that's what u r asking. Quote SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74 Link to comment Share on other sites More sharing options...
tctdh11 Posted August 29, 2011 Report Share Posted August 29, 2011 witch one? the one on the broom!!!! Quote TEAM DC www.dcsoundlab.com 2003 Tiburon GT V6 6 Speed Ported Clam 6 12" DC Audio XL M2's 2 American Bass 1100.1 1 American Bass 350.4 3 D3100, 1 D975, 3 D925 Second Skin Damp Pro and Spectrum. About 75% done 153.6 Sealed on dash at 34hz My OLD Build Log New Build Log.. DC XL M2 4th Order in my Tiburon Link to comment Share on other sites More sharing options...
Mr Godly Posted August 29, 2011 Author Report Share Posted August 29, 2011 witch=scary woman that rides a broom which is the version fo the word you are looking for I was just being funny, or trying anyway. oh well i have speech problems but when i split the remote wire from the radio connected to the harness do i split both ends of that wire and tie them in with my amp remote wire? Which is why I wasn't an ass about it yes you need all 3 wires to connect. That wire also turns your radio on. Ok thanks alot Quote Link to comment Share on other sites More sharing options...
Blackedout Posted August 29, 2011 Report Share Posted August 29, 2011 Tap into the switched 12v wire. Run one run straight back to the amp. Then daisy chain the remote wire from one amp to the other. I'm not sure what you guys are getting at with 3 wires. There's only one wire that your tapping into and 2 end points that it needs to go to. Quote Trunk Build Log Link to comment Share on other sites More sharing options...
bigmescan Posted August 30, 2011 Report Share Posted August 30, 2011 I think he was asking to hook all 3 together on one power wire. That's how I read it. But I could be wrong. That's why I explained it the way I did. Quote SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74 Link to comment Share on other sites More sharing options...
310_cutty Posted August 30, 2011 Report Share Posted August 30, 2011 The remote wire from the H/U gets wired to the remote terminal on the amp not to the switched 12v from your car!!!! Quote Link to comment Share on other sites More sharing options...
Katt Posted August 30, 2011 Report Share Posted August 30, 2011 The remote wire from the H/U gets wired to the remote terminal on the amp not to the switched 12v from your car!!!! If he's using stock, Then it would be the Switched Ignition, If hes using a Aftermarket deck, then he can use the Blue Remote Wire. If your using stock, Personally, i would put a Relay on it, That's what i did with mine, Both my amps made a pop sound when they turned on, So i did it with a relay, then it quit. Just a suggestion, Dont have too though. Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
