Some Google Sketchup Bordom
hey roscoe...i went back and cleaned up things considerably (even though u cant really notice....shit was a mess though)...i also changed the port positioning too...and i actually figured up all the numbers...each chamber is 6.3gross, 4.65net, port is 12" x 5" x 22"long (the wood itself for the port is only 19.5"....added the end correction), tuned to 35hz...
Posted Image
Posted Image
i likes me some audio stuff...
and here are the dimensions for each enclosure in case you wanna double check...i could be off, its been a long day...each enclosure is 34.75"deep (internally)...all of thse measurements are internally as well...
Posted Image
i believe i know exactly the subs you are thinking off.....based on the few specs you gave...if this ever happens, its gonna be awesome!
That blue little box on the top with the tools, click on it and you will see solid walls.
And where you plan on putting an arc. draw a square, then draw an arc going diagonally across the square.erase the inner side of the square separated by the arc. Then use "follow me" to drag the arced square around the circumference. Then erase the outer part of the square
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
Well I am thinking of the same brand used currently, so if thats it you are right!
i knew...so u like the first or second enclosure better?
