DC Sound Lab
Got 3 bottles one with red tape, one with yellow, and a spray bottle. What one is for which part.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
Ca is for the spiders and cap. And the yellow is for the surround. And the activator is for the ca on the spiders.
PPI dbl din
DC Level 3
DC audio 2.0k
Is my above post correct.
PPI dbl din
DC Level 3
DC audio 2.0k
Actually dc says use the rubber on the dustcap also. You have a chance of it coming off if you use ca on it
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I have never used the rubber on any recone I use ca on all of it never had a problem but that's my way there is more the. 1 way to skin a cat lol
does anyone wtf is the little foam black rings are for in my recones???
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
There for nothing it's just packing shit rob throws in
o haha i thoughed it will be used to cover it up when grinding baskets or somthing haha
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
