im running a phenix gold tantrum 1200.1 and its throwing a tantrum. i have it bummpin real good then it will just shut of & wont turn back on for a min or so & when it does the first bass hit that comes it shuts off again. is the amp screwed up of is this something else? also< i have the big 3 on this car but my voltage still drops to like 10.7. is this cuz of the non efficient amp or do i just need more juice?
Bring on the Rockfords!!
bad ground possibly. what upgrades have you done besides the big three and what gauge wire are you running to the amp
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Sounds like a protection issue. If you constantly have low voltage, the amp could be overheating and going into a thermal protect mode. Has it been doing this since day 1 or just as of recent?
formerly known as Jaylor Swift
Like Bass Stalker said, could be bad ground. Might want to check all of your wires running to that amp and your fuses. Could be the amplifier, but more than likely it isn't.
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
how many drivers are you using, and how are they wired? you could be possibly running that amp below its spec, and it now just finally said "NOPE I dont want to do this anymore" and yes, you obviously need more power to supply your demand. Pix of install? more detail on how you did your ground, more detail of wiring in general could help us help you more....
I love my staffie :good:
So anti FACEBOOK it isn't even funny
well i had it in my truck b4 and it did it very seldome. but that was only when i really cranked it out for a while, now its in my car and it just started like 2 days ago.
well, we cant help you much unless you give us more info.
Upload some pics of the wiring, the amp, and the connections. Pretty much everything but yeah, it'll definitely benefit you more. Someone will understand the problem once they see it.
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
1 Lanzar 3000
1 Audiopipe 1500
The Big Three
19" rims
and more..
i have a really dumb set up, but it works. for music, i have an alpine type r 10" duel 4 ohm hooked up in parallel then when i watch movies i use my rockford shallow mount p3 12" sealed duel 2 ohm in series. my grounds, like i said i have the big 3 using knukoncepts 1/0 wiring. then for the amp i have it bolted to the same place the rear seats are bolted to because it goes strait into the frame. the amp has knukoncepts 4 gauge wires and their 120 amp fuse. also, if the info is needed, my deck is power acoustics 8.3" fold out monitor w/ bluetooth.
10.7 voltage drop? Holy crap, can you play it at low volumes? Sounds like it might be that, 10.7 is really low.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
  • Who's Online   0 Members, 0 Anonymous, 833 Guests (See full list)
