im running a phenix gold tantrum 1200.1 and its throwing a tantrum. i have it bummpin real good then it will just shut of & wont turn back on for a min or so & when it does the first bass hit that comes it shuts off again. is the amp screwed up of is this something else? also< i have the big 3 on this car but my voltage still drops to like 10.7. is this cuz of the non efficient amp or do i just need more juice?
Bring on the Rockfords!!
bad ground possibly. what upgrades have you done besides the big three and what gauge wire are you running to the amp
Like Bass Stalker said, could be bad ground. Might want to check all of your wires running to that amp and your fuses. Could be the amplifier, but more than likely it isn't.
2004 Melky Toyota Scion xB
Kenwood Touchscreen Headunit
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
6 Tweeters Audiopipe
1 Rockford Fosgate T2500.1 bd
1 Lanzar 3000
1 Audiopipe 1500
2 Optimum YellowTop Batteries
The Big Three
19" rims
and more..
http://www.stevemeadedesigns.com/board/topic/119197-build-log-scion-xb-4-15-kicker/
how many drivers are you using, and how are they wired? you could be possibly running that amp below its spec, and it now just finally said "NOPE I dont want to do this anymore" and yes, you obviously need more power to supply your demand. Pix of install? more detail on how you did your ground, more detail of wiring in general could help us help you more....
I love my staffie :good:
So anti FACEBOOK it isn't even funny
well, we cant help you much unless you give us more info.
Upload some pics of the wiring, the amp, and the connections. Pretty much everything but yeah, it'll definitely benefit you more. Someone will understand the problem once they see it.
4 15" Kicker CVR
4 6" Audiopipe
6 8" Audiopipe
1 Lanzar 3000
1 Audiopipe 1500
The Big Three
19" rims
and more..
i have a really dumb set up, but it works. for music, i have an alpine type r 10" duel 4 ohm hooked up in parallel then when i watch movies i use my rockford shallow mount p3 12" sealed duel 2 ohm in series. my grounds, like i said i have the big 3 using knukoncepts 1/0 wiring. then for the amp i have it bolted to the same place the rear seats are bolted to because it goes strait into the frame. the amp has knukoncepts 4 gauge wires and their 120 amp fuse. also, if the info is needed, my deck is power acoustics 8.3" fold out monitor w/ bluetooth.
10.7 voltage drop? Holy crap, can you play it at low volumes? Sounds like it might be that, 10.7 is really low.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
  • Who's Online   0 Members, 0 Anonymous, 1416 Guests (See full list)
