michigancapri92 Posted September 5, 2011 Report Share Posted September 5, 2011 ok so putting new system in car going to be about 2500 watts rms and i will be using a XS d3400 as primary and audio batter and was wondering how many amps should i get for charging ? Quote Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED Link to comment Share on other sites More sharing options...
**Hollywood** Posted September 5, 2011 Report Share Posted September 5, 2011 As much as possible , n e thing from 200 up and u should good to go Quote Link to comment Share on other sites More sharing options...
speedball1978 Posted September 5, 2011 Report Share Posted September 5, 2011 270 amp alts seem to have the most output at low idle Quote Link to comment Share on other sites More sharing options...
**Hollywood** Posted September 5, 2011 Report Share Posted September 5, 2011 270 will be great Quote Link to comment Share on other sites More sharing options...
GSanders17 Posted September 5, 2011 Report Share Posted September 5, 2011 x10 on the 270, that's what I'm putting in my Altima. Quote Link to comment Share on other sites More sharing options...
michigancapri92 Posted September 5, 2011 Author Report Share Posted September 5, 2011 how much stress will be put on my engine with running such a high output ? my stock is 70A and i will be chaging the pullys to a ribbed rather than V belt but how much strain will be put on the engine ? and what would be the bare min of AMP needed ? Quote Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED Link to comment Share on other sites More sharing options...
Ray Posted September 5, 2011 Report Share Posted September 5, 2011 220 should get you buy. Hell a 170 would prob work for you Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
michigancapri92 Posted September 5, 2011 Author Report Share Posted September 5, 2011 (edited) 220 should get you buy. Hell a 170 would prob work for you was actually thinking about a 170 and now i need to try to find one that will work or see if mechman can take stock alt beef it up and changed to ribbed pulley or find a 170 alt that i can fab to fit ! Edited September 5, 2011 by michigancapri92 Quote Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED Link to comment Share on other sites More sharing options...
MECHMAN Posted September 6, 2011 Report Share Posted September 6, 2011 At max load your car and system can pull 280a+. You have to figure that you can't play or draw the max output all the time unless you played one note constantly for minutes at a time with your lights and AC on so you can work just fine with proper batteries and a 220a alternator. 270a would be better peak and idle, but will it fit your application? Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
