Witch Amp would you run, and why?
RickyFriery97
Yes. The lower the resistance the more current draw plus higher rail voltage then more heat and shorter life for your amp.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
Exactly what I thought c-fizzy said it wasnt true, and I dont know enough on the subject to debate it. So....
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Now we have to judge this on a per amp basis. Let's say the AQ2200 is rated at 2200 Watts rms @ 1 ohm and draws 200 amps then at .5 ohms it should draw around 250 amps and put out around 2500 watts.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Think about it this way, my aq3500.1 is rated to pull 380 amps at 1 ohm. If I have the gained turned up a sliver, do you think it's going to pull 380 amps? No.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
actually i think it would pull that yeah if you turn the gain up yes it will still pull 380 amps
And you never changed the ohm load.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Ya. If you turn the gain up. But if the gain is turned down, it won't pull 380 amps. So just because it's wired at 1 ohm, doesn't mean it'll pull 380 amps. Like everything else in car audio, there are multiple variables.
under construction
u hate c-fizzy?
  • Who's Online   1 Member, 0 Anonymous, 1479 Guests (See full list)
