sa 10's and saz2500 not as loud as expected
Adjust the gain -- DMM method doesn't work very well, IMO. If you have NO voltage drop you aren't getting much power.
The 4th order probably has a nice box rise across most of the bandwidth as well.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
8" PVC pipe
@ Chode. As of now I'm planning on coming. 3 hour drive , but fuck it, it's a good show.
3 hrs isnt too bad....hope to see ya there
NoFearX18 said:
trainman0978 said:
Find your peak freq with the box then adj gain be careful u won't hear subs distort and will blow them easy. As far as voltage drop box rise is most likely the culprit.
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1386 Guests (See full list)
