Adjust the gain -- DMM method doesn't work very well, IMO. If you have NO voltage drop you aren't getting much power.
The 4th order probably has a nice box rise across most of the bandwidth as well.
So I should just keep turning gain until I see nice voltage drop?
8" PVC pipe
@ Chode. As of now I'm planning on coming. 3 hour drive , but fuck it, it's a good show.
3 hrs isnt too bad....hope to see ya there
NoFearX18 said:
trainman0978 said:
Find your peak freq with the box then adj gain be careful u won't hear subs distort and will blow them easy. As far as voltage drop box rise is most likely the culprit.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
are they new subs ? if so when they break in it will make a big difference
REP
  • Who's Online   0 Members, 0 Anonymous, 1559 Guests (See full list)
