Advice for a new sub
Guest HellTriX
U should get some Orion hcca :) good subs
Uhh no... Not on his power.. They prob would'nt even move. They do like small boxes though.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Most of these suggestions are questionable. As far as I know the DC, Fi, and Sundown stuff mentioned are pretty much SPL oriented. With the only exception being the Fi Q which can pass as a SQL type driver. I would go with a single Fi Q or AA Havoc 12 and get someone to design a box that meets all your listening preferences.
Guest HellTriX
Was looking into building a new box for a single SA-12 to run off my 1000/1.
Seems like 1.75cuft box size would be good the power level?
I think I want to do a fiberglass box where the spare tire in the trunk goes.
I measured it all up and I have a 27" diameter spare tire well at 6.5 inches deep.
The sub is 6.5 inch mounting depth so I can use fiberglass to taper the center up to
around 8" for good clearance on the subs mounting depth. This would put the volume at
about 1.85 cuft after subtracting the 0.14 of the sub. Now the issue is with port size
for tuning at 32hz. Was playing around with a few calculators since I am not up
to date with current calcs for these things and it seems with high excursion subs that
port area becomes important to quell port noise. This one calc suggests a port are of
33 inches using the one way Xmax of 19mm. This corresponds to a port length of about
21.6 inches.
Now this is almost as long as the largest dimension of the box meaning really hard to
implement with the circular design I had in mind. This is not even factoring in making
the box a bit larger to account for the large port volume being used up by the port
(about 0.16 cuft). This would bring total volume to 1.687cuft.
Am I completely wrong here? Would like some further guidance on this stuff since its
been many years since I have build/used ported systems.
Guest HellTriX
Pics of car/current set up?
I just uploaded some pics of the current setup to an old cardomain thing I had.
Current setup
I put a Rockford punch 250W 12" in an old prefab box I had and ratchet strapped it to the trunk just for a temp bass
fill while I plan out a good enclosure and proper sub. For some reason I don't have pics of the molded trunk box I did
but its too small anyway for a good loud system.
Before I blew up the previous JL Audio I used this prefab box for a few years Image.
There is lots of space in that spare tire well to dedicate to a box for a single 12". Was thinking I could run the ports out toward the Amps. But then I would have to extend the ports under the sub to back (opposite side of the amps) so not sure how good that idea is.
Skar vvx's will handle good amount of power and get super low I'm a Skar Audio Rep pm me for prices
www.wooferwarehouse.com
Guest HellTriX
I installed google sketchup just now and did a really bad mock-up of what I was thinking. I have no graphics design or CAD skills at all so its just a rough visualization to get opinions for you guys.
Made the top transparent so you can see the box being mostly circular with the slot port opening under the sub and coming out the back of
the box near the amps. Still not sure on port size/length yet.
Hmm well you looking for a ten or twelve? I know for a fact that the fi q and the aa chaos play great in sealed or ported..feel free to message me with question everyone has loved how flat my boxes have played with my fi q's. Dropping to low 20's
Johns.jpgSuburban Coming Soon
Alpine type x 12" , good for sq and would work I'n your current b0x , and the jl1000 amp would power it nicely
For the price of the Type X I would rather see someone get 2 Type R's they still sound really great, I just don't think that the type x is worth the money
1978 Chevy 3/4 ton Reg Cab Pickup Alpine 9887 Imprint Head Unit JL Audio HD600.4 (Mid Amp) JL Audio HD750.1 (Sub Amp) 2 x JL 13TW5 Shallow Sub's JL C5-650 Components in fiberglassed door mod JL ZR800-CW Mid Bass in the kick panels ***UPCOMING BUILD(2 weeks and counting)*** 8 JL Audio 15" W0's in a blow through 2 Kicker 2500.1
  • Who's Online   0 Members, 0 Anonymous, 1883 Guests (See full list)
