Volt meter question
I have a stinger volt meter but where would be the best location to take the voltage from, i keep getting mixxed opinions and answers. I got a stock battery up front and an hc2000 in the back. At the amp? At the alt? at the front bat? at the rear bat? lmk opinions thanks
Edited by kookz
Walled Police Interceptor
Four 15s
160s
whichever you want the voltage to read from.... i run mine to the rear battery where my amp pulls from but i think its mostly preference
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
you bass amp or w/e draws the most current ;)
also put the meter to where its not up in your face cause they're funkin bright
Im leaning towards the rear bat since its voltage is really close to what the amps getting
Haha, the LED must be like the fucking aq bass knobs they are blinding.
Im also thinking of running my remote line into my fuse box under my dash and fitting it into an accessory plug
Four 15s
160s
From what I have read can’t you just install the volt meter to any 12v source (the front battery) just to get it working and take your reading from the source you want (the battery closet to the amplifier) and adjust the volt meter.
From what I have read you will need to get a reading and have it adjusted anyways, so wouldn’t this method work to?
Back battery or amp. My meter has saved me amps and subs. You want to know when your voltage is dropping dangerously low when playing fulltilt to turn it down. Don't demo at idle that's the worst
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Do you have your voltmeter running directly from your amp?
Edited by brownm3
  • Who's Online   0 Members, 0 Anonymous, 1585 Guests (See full list)
