i have a 9515 DD on an AQ 2200, with big 3 done and XS D3400, i have a 5ft3 box tuned to 30 hz, i had my gain at avout half way the other day, subsonic.. off.. forgot about that on accident, bass boost .. off.. LPF - little less than halfway, when i would turn the gain up a bit it would make like a popping noise.. real nasty, so i am only able to turn it to about halfway
The system is definatly not as loud as i expected it as is, i meen it shoock good at this point and was a descent loud
yesterday i changed the subsonic to halfway, round 25 hz( my guess), its a lot more clear now, but a lot less loud
i just want to know why this thing isnt hitting like it should?im getting frustrated! my friend has a 9512 on a viper 2600, forgot the wattage, and hes running about 100 more watts than me
his is very loud and impressive, yet i can't figure out what im doing wrong, any help would be appreciated thanks
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
How's you're box designed? How much port area?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
ok ...
Depth - 30"
width- 30"
height-16"
"has a double baffle"
my port is 4" wide by 20.75" deep i beleive
so idk i kinda just threw sum numbers on torred right now and i think its 55"2 for port area? i culd be wrong but its what i got unless i enetered something wrong
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
If it's 55sqin of port area, that will be 11sqin per cube since your enclosure is 5 cubes. I'd definitely work on getting a larger port, the more port I added to a DD3515 enclosure, the better (and louder) it sounded. Seemed to like around 17sqin per cube, but that may be different for your situation.
Port is 4x 14.5"??
You should have around 85sqin of vent. Not 55
Hell even up to 95sqin
Your chokin it
And tune to 36-37 man.
No need to tune that sub to 30
What car?
really? i was thinking, and im totally wrong usually.. im trying to learn more
that i would be louder with less port, but that culd be wrong, because it seems like itsnot punching hard like that 12.. its not even getting roof flex :/.. and on the torres it says 10.05 per foot for port ?! idk ha.. i am going to be makign a really good box soon, but would that port area and the box make that much of a difference with the loudness? im feeling id be louder with crap subs at the point i am right now :(
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
Yes you need to add more port area.... How much depends. You will have to play around with it. Id shoot for 14 at first the go up from there to around 17 max imo.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Port is 4x 14.5"??
Your chokin it
sounds like your box is holding you back...id get a design from ray^
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Port is 4x 14.5"??
Your chokin it
a 97 dodge intrepid
, so im actually choking it? i thought i was going big :/ so is that the reason? i am not good on the porting
and why would 35-36 hz be better ? jw cuz i want to tune my next box to that
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
  • Who's Online   0 Members, 0 Anonymous, 2276 Guests (See full list)
