Hey guys my name is Chris and I'm new to this forum so hello everyone! What I'm doing is I'm looking into getting 2-15's for my blow through project on my custom full frame bodied Chevy C10 show truck that we're building now. I'm not far away from getting all my stereo stuff together and want to have it all in stone of what I want when I'm ready to buy. Ok so here's is the list of what research I've gathered on some of the best comp subs on the planet. What I need insight on is what one is the best overall for not only crushing chests, but music SQL. It's ability to play music cleanly is very important to me. I do not want just an SPL juggernaut subwoofer I want it to play anywhere from shit like Hotel California to drummig bass to some serious bass stuff if need be. Ok so here's is the list of what research I've gathered on some of the best comp subs on the planet. I have never heard any of these so keep that in mind and if there is one that you know of that you perfer for what I'm looking for I would definitley appreciate any input! Incriminator Audio DR-15d2, Sundown SA-15, SSA Icon-15 d2,DC Audio Lv3 or Lv4, AA Audio Chaos or Havoc, MMATS P3.0 15, DD Audio 2500b-15 or 3500b-15 thats my list again if there is others that really get down let me know and thanks in advance!
Well this depends also on the power level your looking to run and how big of an amp you can properly power...need any other advice you can message me
Johns.jpgSuburban Coming Soon
Dc audio /thread... JK
Every sub you listed is solid, you need to give us more info like space, power, and budget.
he said its a show truck so im sure hes willing to spend what ever he needs to on this set up correct me if im wrong though and and its a blow through so space on a normal truck bed would be the space he can use so all that leaves is power so what kinda power will u be running to the 2 15s
I would do 2 sa-15's on a crescendo 2k in a 4th order bandpass.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
SMD's on a warhorse. Blowthru done proper. :good:
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
Yeah I'm up for any suggestions on power. Like Hitman said it is a full custom build so I can pretty much do what I want. Keep in mind yes it is a blow through but I would figure that I can only go so far back into the bed because the rear driveline and differential will come up a lot higher than normal because this truck will lay flat on it's rockers. So if you recommend a sub please by all means let me know how much power I should feed her and what the optimum enclosure is for SPL and SQL balanced between the two. Oh and if recommending and enclosure style ie bass reflex/ported please let me know the recommended air space for each sub or total if they are to share the space. Again thank you all for your suggestions it already has helped me a lot!
how much do you want to spend on everything?
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
  • Who's Online   0 Members, 0 Anonymous, 1560 Guests (See full list)
