Fi Car Audio
problem with fi 15 btl
kulynyak
hi... i have one fi btl 15". the ampiflier is formula-x 4000d. the problem is with terminal cable. i was change and the cable came apart again..
can someone tell me why it do??
Picture?
Authorized Ascendant Audio Dealer! Message me for information.
If you can't explain it simply, you don't understand it well enough -Albert Einstein
"I have a plausible excuse for not liking you. And you know why."
Soo..you played it for a long time without a subsonic filter, beat the suspension up, burned up the tinsel leads that are inside of the spider and put external leads on it..and beat on it again..and burned them up too :)
One would think that there might be something wrong..if you've burnt two different lead setups up..twice..
Subsonic filter is your friend man, get a recone from the dealer in Greece! If you do not fix what is wrong with your install you are going to keep having issues and keep buying recones too.
subsonic filter it was at 25hz. it is ok??
bass boost off
phase off
gain at 50%
and lpf at 80hz
in anything here wrong??
Your SSF should be set to about 5hz below tuning
Your gain should be set according to your input voltage
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
bass boost off
phase off
gain at 50%
and lpf at 80hz
when you say according to your input voltage what you mean??
whet i play music the voltage going to 12volts.
bass boost off
phase off
gain at 50%
and lpf at 80hz
What does your electrical system consist of?
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
  • Who's Online   0 Members, 0 Anonymous, 1639 Guests (See full list)
