Noob question about output
Mr.JaunDurfle
So I have two Kicker zx750.1's running to two Boston Acoustics SPG555-2 subs. So one amp to one sub. The subs are single coil two ohm, the amps are rated for a two ohm setting. My question is are the subs seeing the 900 plus watts that the amps put out at two ohms?
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
in reality, no theyre not seeing 900 watts due to voltage drop and imp rise.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
You can always clamp them and find out what you're actually getting.
only half of this statement is correct. you are correct about voltage drop, but since music is dynamic impedence rise isn't really a factor.
this will only give you what you are getting out of the amps at a certain frequency not a particularly efficient way of testing how much each sub is getting on music.
So the amps should be seeing a two ohm load is what I should have asked. Are they seeing two ohms?
2 ohm nominal is possible (not sure as i've never put a dmm on those subs).
as far as seeing a 2 ohm load all the time, No. Only at certain points of the up and down movement of the coil is it actually going to have a resistance of 2 ohms.
Edited by cj407
If the subs are 2ohm each, then in theory, they should be running at 2ohms.
yes they are seeing two ohms, but when playing music, the ohm load varies greatly. so you could be getting theoretically 400w to each woofer when playing music.
  • Who's Online   1 Member, 0 Anonymous, 2008 Guests (See full list)
