DC Sound Lab
How to wire DC amplifier?
If someone had two DC 3.5k's and wanted to run there subs to a 1 ohm load, would it be possible to link the two amplifiers so you can control both with one amp (ie; set gains, bass knob, etc) and still hook 1 ohm load to each sub?
One ohm final load?
I wouldn't do it. When strapped those amplifiers are 2 ohm stable.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Just get a line driver and slave both amps and let the driver do all the work
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
Why would you do that when you'd still have to gain match?
Worst case scenario if all you're looking for is a single bass knob, get a PAC LC1. Much cheaper than buying a line driver.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
One ohm final load?
So if I understand correctly when strapped this amp is now 2 ohm stable at 7000 watts?
I thought when you set one DC Audio amp to master and the other DC Audio to slave both amps ran on the master amps settings (gains, bass knob, etc). I was under the impression it was like one big ass amp.
And thanks for the PAC LC1 suggestion. Didn't know about that. But if I had the choice i would rather use DC's bass knob with clipping indicator. That is until I get SMD's clipping detector device.
It's one of those things where "If you have to ask, don't."
But if your electrical can handle both amps at a now less efficient state then before then you could wire them at 1/2 ohm each (1 - 1 ohm load going to 2 amps strapped).
For 2 3500's strapped to 1 ohm final i'd suggest at least 4 EXTRA batteries (read 5 total) and a good dual alt setup, for a BARE MINIMUM.
Even then, if you can't watch a voltage gauge and know when to turn it down, just don't do it.
And if you're the type of person who would blow an amp by wiring it like this and being stupid about it, then blame it on the company, DEFINATLY don't do it.
How do u kno if he's " that type of person " ? That's a bit harsh ,,,,,
Not at all
Something like this, if you have to ask you shouldn't be doing it
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
  • Who's Online   0 Members, 0 Anonymous, 1939 Guests (See full list)
