box rize?
Nice thread jack there hollywood.
OP to find what your box rise is, you need a clamp meter and a DMM.
it's pretty simple, really. hook the dmm up as ac voltage to the speaker leads, and clamp the clamp meter around ONE speaker wire (pick one, positive or negative, don't matter) and set it on amperage.
voltage X amperage = wattage
voltage / amperage = resistance < that's your rise
(i may have that backwards though, check amperage / voltage just in case)
If you want LESS rise, a bigger box often helps, as well as things like port flares and SMOOTH resin.
I cant spell. and was still half asleep. I hate the search bar it never gives full anwser. thank you. Ill have go an buy a clamp meter and the dd-1.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
Wow i left out the '. i did not realize this was spelling class.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
  • Who's Online   0 Members, 0 Anonymous, 460 Guests (See full list)
