How do you find what your box rize is. kinda a noob. but i want to learn what it is.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
Use a true rms clamp meter and a dmm on your speaker output you test voltage from pos and neg leads and you test amperage from pos speker output then its simple math sir you multiply to get your wattage then you just divide to get what ohms it is at .from there you figure in what your wired at to what your reading was for example I have my dds wired to .35 I've clamped 12k at 1ohm out of the pair so .35 to 1ohm is .65 ohms of rise
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Jesus :-(
You mean you also realized this thread pops up every other minute?
I was in jail for the last couple months. Paypal reversed everything, money sent back thank you. Amps here, and not sent as money was returned.
Thank you
  • Who's Online   1 Member, 0 Anonymous, 2756 Guests (See full list)
