XS Power
sounds like you overcharged it. Thats the only time i have ever seen it happen...i left a POWER SUPPLY (not a charger) on my Tahoe all night on accident in Vegas (CES 2010) a few years ago and came back to 10 HOT batteries in the morning. One of them swoll a little. TOTALLY my fault. It took ALL DAY for them to cool down but after they did, the swelling went away and the battery was fine.
Follow my Tweet (Twitter)
I got similar thing happening to my kinetik hc1800. It swollen on the side's, but just a little bit.
Btw, will it be fine to mix kinetik and xs power batteries. 1 kinetik hc1800 with xs power d3100?
Edited by LoudBimmer
Never charged above 16.5 and that was only at shows I have 3 mecman alts controlled by there adjustable harness and I have stinger volt meter on my battery bank to always keep a eye on voltage I'm a stickler for that I also have the xs 14v intellicharger and usually hook it up to back batterys every couple weeks. I have 6 total batts 2 up front 4 in the back the rest are fine. I'm hoping it was just heat. Later on ill change it out to be safe thanks bro.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
The battery is fine. I would just put the heat shield around it when you get a chance. If anything else comes up just give me a call.
One thing to keep in mind is if you are going to be doing a lot of demos or going to be doing demos at all you can just leave the hood cracked and it will help let the heat out of the engine bay.
Thanks nathan and that's what I do mainly to help keep my alternators kool I've lost 4 of them from heat already. Also I love xs power and the 14v batterys especially. They have helped me tremendously in the lanes this year and to put up big numbers. Wish me luck at california meca finals this weekend
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I do not suggest mixing the batteries together, because they are made up of different chemistry and design. In the short term you would be fine, but over time you may see some issues.
thats coo bro, i know your not no peanut......you have been around the block a few times :D Im just trying to help get to the bottom of it. Sick setup being on a 14v system. I want to do that but i dont wanna rip my entire truck apart :D
Yeah we have seen some big gains from guys going to the 14V set ups. How much did you gain?
Most do not think to keep the hood cracked open and do not think about the added heat.
  • Who's Online   1 Member, 0 Anonymous, 1661 Guests (See full list)
