XS Power
I noticed today that my xs d1400 battery under my hood that I use in the stock location is swelling on the side. I now the s series has a better case and is meant for under hood applications. Do u ma ke a s1400? And is this battery goin to fail? I have a heat shield around my other one up front is it to late for this one
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Damn it Ray doing work on your shit bro.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
They have a s1400 listed on their site
http://4xspower.com/products/agm/
Edited by JPagan
d think its toast ray. Either that or take the risk of the case splitting.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Ill take pics today. Damn I'm tapped on cash too can't afford more expenses
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Should be fine Ray. I have a stinger thats so deformed you would be scared to be close to it. It sits at 13.1 after sitting for 6 months. It went rounds with a Napa battery charger putting out 17+ volts all day at AI a couple years ago when we did our 27 woofer test. Still works fine, lol.
Clovis Custom Audio 559-392-3600
96 Silverado Single Cab
2-DD9515's Cut-through
1-DDSE Amp
Stock electrical and a couple small stingers, LOL
thanks bro heres some pics of it and im going to buy a heat shield to try and protect it from further swelling
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
That looks like your battery itself is fine just the casing is overheating. Is this part of your battery near your engine or your radiator? I dont think your battery is ready to explode, just was overheated from the engine or any other nearby component that is really hot and caused the case to give way. Id see if you can possibly get a steel case for around the side and possibly part of the top to protect it from heat. Maybe if you really want to be overkill make a protective case and put some second skin or something on it to try and fend the heat from going through the metal onto the battery. Just if you do make a case make sure you have a good amount of room around your terminals to protect against a short.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
The battery is fine. I can not tell from the picture how swollen it is, but the way the case is made on the 1400s they will have a little bulge right off the production line. The way the case is reinforced on the sides it kind of sticks out a little in the middle (about a 1/4").
It is always good to put a heat deflector around it if it is under the hood though. There is a company called DEI that makes a battery blanket product that helps to keep the heat away from the battery. If you are doing demos for long periods of time with the hood closed there is a tremendous amount of heat that builds up under the hood.
What voltage are you charging at?
15 .8 to 16.1 daily. And yea I have that heat blanket on the othe side I went the cheap route this time and used the reflective wndow shade thing lol cut it to fit. 4 dollars verses 31. I'm goin to change it out asap just don't have the funds right now. So the battery is good? Just protect it from further heat? Its bulging a good 3/8 to 1/2 maybe on both end only
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
