Hey guys
Long time reader, first post.
Need help with my first box, i just want to make sure that i got everything right before i spend time and money.
i have had 2 12" Audiobahn aw121t woofers sitting around, and decided to do something about it.
I have all the specs listed below:
Fs - 33.4hz
qts - .64
Qes - .69
Qms - 8.89
Vas(litres) - 49
Vas(Cu. Ft. - 1.71
Re - 3.3
Le - 2.42mh
Mmd - 148grams
Xmax -
RMS - 550
Sd - .048
Freq Resp - 26hz - 1khz
Efficiency - 92.8
Displacement - .15
They recommended this for 1 sub for SPL:
air space - 3.2
port size - 4x10.5
port velocity - 6.54
-3db - 29hz
Tune freq - 38hz
Sub disp - .15
port disp - .141
total vol - 3.5 cu. ft.
My dimensions, designed to fit recommended SPL setup by AudioBahn:
Box
H - 40 in
W - 97.5 in
D - 60.25 in
Port
H - 5 in
W - 10 in
D - 12 in
Will this be the best setup to get some good numbers and hit lows.
If this is complete shit, can someone help me design a box.
Cheers
97 inches and so on? I think you got mixed metric and standard
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
With those meauserements i think it should be enough space for them. Im no box pro so i cant design you one but there are some reputable members thay do
I would go with ray. He might be booked up at the moment but its worth the wait
Hahah damn cody
Build Log
Feedback
This is just an experimental build, being my first build and all.
I dont want to really annoy the full pros on this since its not serious, but in the future i got some plans.
Really all im looking for is someone to say, yes thats perfect, or No try doing this and this.
Man I can see your chompin at the bit, be sure you start your build with a pair of safety glasses! It would help to know the vehicle make and model, and how much power you going to put on them.
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
Well this is the final design of the box, it has changed around 5 times till i got something that will fit, yep i built 5 test boxes to see if they fit in the trunk.
this box is roughly 40hz or there abouts, hope it sounds good.
What do you think?
Port calculates to 32 hz with those dimensions, is it 12" deep, right?
1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire
*3 Kinetik 2400s and a Mechman 270A alt in the future*
  • Who's Online   0 Members, 0 Anonymous, 5025 Guests (See full list)
