Lookin into getting a glock soon & want to know what pros/cons between carring a glock 19 or a glock 21/30.
Yes there all glock
yes one is 9mm
yes the other are 45mm
just looking for oppinions on how glock owers feel...
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
I say go with the 19 the way ballistic are these day. A 9mm can perform just as good. But some people would disagree and it just has never been proven or settled in an augment which is better plus go to the gun shop and hold ea model for periods of time to c which 1 u like and fits in ur hand and if ur able to rent 1 or use a buddys shot them to c which 1 u perfect
G.R.I.T.S
ballistics wise 9mm and 45 are worlds apart. big slow bullet or smaller fast bullet. either will get the job done. I think the 9 is a litlte slimmer and has a higher magazine capacity. You'll get those that will argue that if you are good it only takes one. do what was said about. handle them both. get hte one you are comfortable with. I carry a glock27 daily.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Exactly as stated. Go to the store, hold both and see what feels best. Something to keep in mind, if you plan on doing much target shooting with it, 45 shells aren't cheap, trust me
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
I had the glock 23 in 40 cal and it was nice and compact but imo the 40 kicked real hard hurt my hand and was uncomfortable id go with the 9mm imo if you want 45 get a colt ,kimber, para ordinance etc
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I carry a Glock 23 40 caliber Compact pistol EVERY day... Its the perfect size... Definitely go to the store and grip all the pistols because you want it to be comfortable in your hand
Team MaxRetribution
Si Vis Pacem Parabellum
I use to shoot hydrashocks and talons out of it real hot loads. Maybe that was the reason and I had the preban cali clips either 14 or !6 I don't remember its been 10+ yrs plus a 28 ext round one. I do miss that glock
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
It all depends what the weapon is used for, me personally, I always carry a .45. That is because if I must use it, I prefer the stopping power. My 9mm I use when I want a smaller conceal, but with that one if I must use it, it will be a double tap, vs a single with the .45. They are both excellent weapons, just depends what the application is for. Now the .45 has a recoil you must get use to. IMO get the best of both worlds get a .40
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
  • Who's Online   0 Members, 0 Anonymous, 730 Guests (See full list)
