My good friend just bought a 2005 bmw 545i. we are trying to install his 3 12s and amp. power and ground connections were very simple with the battery in the trunk, but getting signal and ignition seems to be a problem. id like to keep all the wires in the trunk. i know the factory amp is on the drivers side in the trunk and have found a thread that lists what wires left and right are. but it seems like the signal fades in and out. so my question is, does anyone know what are the correct wires to get a sub signal from? and is there ignition in the trunk? and if so where? i have tried tagging signal with a loc from the 4" speaker in the rear deck only to find out that that channel is high passed and has little to no low freq passing through that channel. any suggestions or PICTURES would be greatly appreciated.
Thanks,
Brandon
ok so ive done a ton of research and found out where the ignition wire is...
picture of ignition wire
but i still need to figure out proper sub signal if anyone could help me out!
OH, and it does have the logic 7 system if that makes a difference
Edited by soundsystemaniac
does it have a factory subwoofer?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
there are 4 full range outputs behind the radio hi level
these 4 outputs drive the front doors and rear door mids
the center, factory subs under the front seats, and rear deck speakers are all ran off the factory amp.
you need to put a hi-low adapter behind the radio up front.
all other signals are x-over
yes, they are under the front seats
Should have 5 1/4 or 6.5 bass in the rear deck no? High low converter to that?
just some 4 inch speakers that are high passed in the rear deck.
thanks ray, happen to know what colors i should tag off when i pull the radio??
