Although it's not the ideal place to mount the amp, sometimes you may not have much choice. Just use rubber washers or similar when you mount the amp.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
yes.the vibrations from the box will loosen internals on the amp.i myself have never had a problem with it,and my boxes werent braced all that great but they didnt flex very much either. if you have room id do the back of a seat but if not just make sure you pick a sturdy part of the box and try to double wall it if you can.you can also try some some rubber pieces between the amp and the box to help absorb some vibrations
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
Both of my amps are on the box with no problems what so ever. Box is 1.5in thick on front, back and sides and 2.25in on top. For the 5k I used 3 washers on each foot so air could flow all around it. For mid/high straight to the box.
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
somone told me that if you bolt the amps to the sub box that the amps will fall apart?
thats a huge load of crap. i have a TIS audio 1800 that ive had mounted to every one of my last 3 boxes, and my new one that pounds much harder. your amp is fine. you just need to make sure it can release heat.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Alright thaks! :good:
  • Who's Online   0 Members, 0 Anonymous, 1710 Guests (See full list)
