most radios CANNOT kick over 4-5 amps on the remote circuit. if they did a fuse would be put inline. MOST can only provide an amp. this is why I always put remote on a relay....always.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
I agree with you on this one superjay. I would have ran a relay if i had problems turning on any of my equipment but luckily i didnt. It would be of best interest for a relay if you have problems turning on the amps or only a select few if any turn on. Most of the times headunits only put out around 850 milli-amps of current through the remote wire so that isnt crap for some amps to kick on with. The relay trick will give it the power it needs to kick on and keep it running and not have you worrying about stressing out the headunit to supply all that power to the amps since the relay is doing the hard part for you.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
