Awhitewookie Posted September 23, 2011 Report Posted September 23, 2011 Yesterday I decided to put my system back in because I missed it. This is what I have: (4)Kicker 12's dual 2ohm Audiopipe 3001D wired at 4ohms 1/0 gauge knu konceptz wire 350amp fuse I don't remember the exact specs of my box, but it is around 5cubes, ported, tuned at 34hz I hooked everything up and turned it on, the subs get power and play. But they are not actually hitting at all. As if the highpass filter switch was turned on or something. I dont exactly know how to explain it, but it sound like i have (2) 6x9's instead of my 12's that hit pretty hard. Its as if its barely getting any power at all. I checked the gains and amp settings and everything looks fine to me. The connections are good and tight, ground is good, fuse is good. Any help is greatly appreciated! MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
mullet Posted September 23, 2011 Report Posted September 23, 2011 Looks like you have 8 coils to wire, could be that something was wired wrong and some of the coils are out of phase
zx10intn Posted September 23, 2011 Report Posted September 23, 2011 my guess is you have wired them up wrong, i assume you are attempting to wire them to a final load of 1 ohm in series/parallel and somewhere you got some wires crossed edit: also, after thinking about it, you could have either missed one coil or had a wire from one coil come loose that would also act like you are describing 1969 Chevy Chevelle 20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's Mechman 250amp cs144 alt w/AVBM Kinetik 1800 main battery/Kinetik 2400 in the trunk Pioneer AVH-3200dvd Headunit (2) sets of Hybrid Audio Technologies Imagine components up front (2) DD 3512's d4 coils Sundown sax100.4 component amp Sundown saz-3000d subwoofer amp 5ft^3 box tuned to 34hz MY BUILD
Guest Posted September 23, 2011 Report Posted September 23, 2011 just for reference, you CANNOT wire that amp to 1 ohm. its 2 ap 1500's in 1 case so they're internally strapped so wiring it to 2 ohms makes each amp see 1 ohm. the only way you can wire them is like this edit: but just quadruple check your wiring with that diagram and you should be set
mullet Posted September 23, 2011 Report Posted September 23, 2011 I was assuming from the mention of the amp being wired to 4 ohm that there would be something like this each coil = 2 ohm each sub = coils in series to 4 ohm each sub pair = series to 8 ohm/parallel to 2 ohm 2x pairs = parallel to 4 ohm if each pair = 8 ohm/series to 4 ohm if each pair = 2 ohm LOTS of wiring possibilities leads to LOTS of chances to miswire something
RooTxBeeR Posted September 23, 2011 Report Posted September 23, 2011 sounds like they are wired wrong and seeing cancelation due them being out of phase. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Awhitewookie Posted September 24, 2011 Author Report Posted September 24, 2011 Thanks guys! I'll be able to take a look at them tomorrow MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
fox_racin4 Posted September 24, 2011 Report Posted September 24, 2011 Easy way to check, unhook subs touch pos speaker lead to battery + and take neg. speaker lead and touch it to battery - subs should all move snd all move the same way. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
