i've always wondered something. is say 155db at 25hz or 155 db at 80hz.? or would the be the same since the have the same db rating
Team DBs (Driven By sound)
they are the same loudness. but the lower frequency will create more pressure making it appear louder
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
cool. i like the low low end. i wanna get sum good numbers at a lower hz area. i wanna be a wind machine on wheels. well some day i will
I've been in a 28hz 156db vehicle. It didn't hurt but was impressive anything above 40 especially 50 an up will digggggg! in your ear and sound a lot louder
Edited by dc98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
a 156 at 28hz is alot more impressive than at 50 or 60hz.
I agree with this. It's not easy being that loud at that low of a frequency. I love lows
