power acoustic?
ngriggs
Would a power acoustic bamf 4000 1d put out 2000 watts rms for my 1 ohm dvc fi btl? I looked at the owners manual for the amp and it said it does but I just want to make sure. It also has two speaker outputs and I don't know if this makes a difference for the ohm load?
Thanks,
No because power acoustik is overrated a bit, and the amp is supposed to make 2k at 1ohm rms I'm pretty sure, and a dvc 1ohm sub wires to 2ohms or .5ohm. I could be wrong on the Amps output but I'm pretty sure
Oh and most monoblock's now and days have various speaker outputs, the terminals are connected internally and the companies just do that for ease of wiring, it doesn't affect the ohm load
Edited by kam311
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
PA is way over rated.
head-unit: pioneer avh p-4300DVD
2 Fi btl n2 18's
1 dc audio 5k
1 dc audio 175.4
4 sets of fusion CP-CM50 components
1 mechman 270 amp alt
3 XS Power D3400
80 Mil Sound Deadener by audio technix
all in my 2003 chevy suburban.
It is supposed to put out 2200 watts at 1 ohm so does that mean it most likely puts out 2000?
Even if it did do 2k at 1ohm (which I highly doubt) your sub doesn't allow you to run at 1ohm anyway
so far...
What about the 5500 watt amp then?
like 1800w at the MOST.
edit: just go with a good brand man, so many people have come on here being all like "my power acoustik amp doesnt work!!! :(((" and we tell them time and time again, that they bought a shitty amp.
Edited by Kranny
Max that amp should make is like 1,300 watts at 1 ohm, and you're not going to see good power output at 2 ohms wired on the BTL. Save up, upgrade the electrical and get a better amp. It will be much more worth it in the long run.
  • Who's Online   0 Members, 0 Anonymous, 821 Guests (See full list)
