Autruche Posted October 7, 2011 Report Posted October 7, 2011 Quick solution; use only 1 coil from the DVC sub... In truth though, don't do it, different subs have different TS specs and will cause a slight bit of cancellation. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
awall1022 Posted October 7, 2011 Author Report Posted October 7, 2011 Quick solution; use only 1 coil from the DVC sub... In truth though, don't do it, different subs have different TS specs and will cause a slight bit of cancellation. Wouldn't that one coil burn up faster Quote lifted trucks gorgeous sluts a pretty face and slammin bass My current Set up Car less I Do Ported Box designs/cutsheets with 3d google sketchup model just PM i would really want an in-depth guide Just flip the fucking thing over
little-kid-wit-bass Posted October 9, 2011 Report Posted October 9, 2011 Quick solution; use only 1 coil from the DVC sub... In truth though, don't do it, different subs have different TS specs and will cause a slight bit of cancellation. Wouldn't that one coil burn up faster Possiably. Just stick with the not doing idea. Quote I cant afford anything... forum.realmofexcursion.com/members/little-kid-wit-bass.html Youngest active user on ROE
nismo923 Posted October 9, 2011 Report Posted October 9, 2011 Would it be possible doing it in two chambers totally sealed off from one another and on separate amps? Each amp matched to the sub they are driving? Quote "If you're new. Stay away from 4000 watts please." C-Fizzy
kam311 Posted October 9, 2011 Report Posted October 9, 2011 Would it be possible doing it in two chambers totally sealed off from one another and on separate amps? Each amp matched to the sub they are driving? Yeah that would be possible and it would work, but makes no sense whatsoever and your much better off just getting two of the same subs, by the time you do all that you could have done it right already and it's much easier Quote so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
Watch the bass Posted October 9, 2011 Report Posted October 9, 2011 Let your friend sell the single and buy another dual sub. So he can use the max out of his amp. Quote "in the abundance of water, the fool is thirsty" Bob Marley
awall1022 Posted October 9, 2011 Author Report Posted October 9, 2011 Let your friend sell the single and buy another dual sub. So he can use the max out of his amp. Yeah I convinced him to but we can't find a other hes just gonna sell em both and get a FI or AA 12 Quote lifted trucks gorgeous sluts a pretty face and slammin bass My current Set up Car less I Do Ported Box designs/cutsheets with 3d google sketchup model just PM i would really want an in-depth guide Just flip the fucking thing over
Metelface420 Posted May 17, 2021 Report Posted May 17, 2021 I'm facing the same problem. What if I were to wire one up to its own amp or different channel on the same amp Quote
