So my friend recently got a truck, and yesterday I installed 2 pioneer 6x9's in the door for him. However, I dont know if the connections are good. I just twisted the wires and taped it. They play, but is there anything I should do to make it stronger? thanks.
Butt connectors or the best option is solder and heat shrink.
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
You can go to like advance auto and get a small box for $3 ( if I remember correctly) and something to crimp them down.
EDIT: the butt connectors that is
Edited by itsanthonyyadigg
Solder and heat shrink will always be your best connection.
Big 3 with Yellow Top
Spend a little money on it if your going to use it alot. I have had Harbor Frieght ones burn up fast.
And make sure you buy 60/40 solder wire too.. most important part. :lol:
i use butt connectors the most often just because its quicker. but you do have the chance of over crimping or under crimping.
remember when you solder to heat the wire until the solder melts against the wire. the wire should soak it up. putting a little solder on the iron first helps heat up the wire faster. and dont forget to put the heat shrink on before you solder lol.
