pitbullninja Posted October 6, 2011 Author Report Share Posted October 6, 2011 How come? :s Quote Link to comment Share on other sites More sharing options...
Jd1102 Posted October 6, 2011 Report Share Posted October 6, 2011 How come? :s if you get dual 1's then final ohm load would be .5ohms(Parallel wiring) or 2 ohms(series wiring) Quote Link to comment Share on other sites More sharing options...
pitbullninja Posted October 6, 2011 Author Report Share Posted October 6, 2011 Ugh so 2 ohm sub would be 1 and 4? Quote Link to comment Share on other sites More sharing options...
pitbullninja Posted October 6, 2011 Author Report Share Posted October 6, 2011 No get the dual 2. And wire it parallel, it will give you a 1 ohm load. Ok so for sure get the 2 ohm sub Quote Link to comment Share on other sites More sharing options...
vettedude102 Posted October 6, 2011 Report Share Posted October 6, 2011 (edited) No get the dual 2. And wire it parallel, it will give you a 1 ohm load. Ok so for sure get the 2 ohm sub Unless that amp can do. .5 daily and your electrical can handle it. Safe bet get the d2 Edited October 6, 2011 by vettedude102 Quote 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock Link to comment Share on other sites More sharing options...
pitbullninja Posted October 6, 2011 Author Report Share Posted October 6, 2011 Well the amp can but idk about electrical Quote Link to comment Share on other sites More sharing options...
Cashdollar2009 Posted October 6, 2011 Report Share Posted October 6, 2011 When ordering the N2 select the Dual 2 option. This will allow you to wire it to 1-ohm nominal. Don't try to run your amplifier at. 5-ohms. Yes the amplifier is capable with proper electrical, but from your questions, you will be more than happy leaving it at 1-ohm. When the sub comes in there will be two + and two -. Wire the + to the other + and then to the amplifier's +. Next wire the - to the other - and then to the - on the amplifer. You will then be good to go with a 1-ohm nominal load on your amplier. Quote On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not. Link to comment Share on other sites More sharing options...
corey0928 Posted October 6, 2011 Report Share Posted October 6, 2011 What does your electrical look like Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted October 6, 2011 Report Share Posted October 6, 2011 Get a dual 2. You can wire it to 4 or 1 ohm. Look up ohms law for more info on ohm load stuff and resistance. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
pitbullninja Posted October 6, 2011 Author Report Share Posted October 6, 2011 When ordering the N2 select the Dual 2 option. This will allow you to wire it to 1-ohm nominal. Don't try to run your amplifier at. 5-ohms. Yes the amplifier is capable with proper electrical, but from your questions, you will be more than happy leaving it at 1-ohm. When the sub comes in there will be two + and two -. Wire the + to the other + and then to the amplifier's +. Next wire the - to the other - and then to the - on the amplifer. You will then be good to go with a 1-ohm nominal load on your amplier. Thanks bro Quote Link to comment Share on other sites More sharing options...
