Need some help, tried to google it, but no answers.
Just hooked up a new kenwood today and it will only turn in if the red and yellow wires are spliced together.
Also my speedometer light doesn't come on now.
I checked all the fuses, but none are blown.
Vehicles is a 2001 S-10.
If anybody in the Sacramento area has a vehicle for sale for less than $1,500 get at me. I'm open to almost anything that runs.
do you have the adapter harness? and what model was it? like ls lt ect
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Yeah, but I've installed other headunits before and they all worked fine.
Went and bought a new adapter from AutoZone, for GM vehicles I believe.
Edited by S Dime 420
well it seems like either your constant power or switched power wouldn't be working then. unless you may have popped a fuse somewhere
Does that yellow line have a fuse on it? Might be popped.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
I might try a DMM. What are all the major fuses that involve a headunit so I can double check them all?
Actually the problems could be my fault. Before I installed the new kenwood, I was unhooking my amp and wasn't paying attention and the power, ground, and remote all touched together and caused a huge flash and loud noise.
whenever this issue happens to me, i don't deal with the headache and just run extra wires to the fuse block. takes a little extra time, but i still do it anyways
